Bearing Buddy size
FSH 210 Sport
Tranquility Base
I lost one of my bearings yesterday on the way to the lake, I did a search of the site looking for the bearing buddy size for a late model shore lander tandem axle trailer and couldn’t find any results for the exact size. I used an amazon link @Dixemon posted, and poking around on Amazon the size mentioned for “boat trailers“ is 1.980”
Battery is dead in my electronic caliper and I can’t find my non battery powered caliper, so thought I’d shoot up a flare and see if anyone knew the size I need.
Thanks!
I liked the trailer buddies on my MFI. They (blue indicators) let me know I had a heat issue caused by a stuck caliper. I used the bra's not the metal caps. Never saw water in the grease. A little grease on the hub or cap should keep out water.
This is an extra one I kept on hand. Kept it after selling the boat/trailer. Did not want to give the new owner too much free stuff.
Okay, I found out the the size / model for my 2020 shoreland’r trailer that has 2960# GWR axles.
I also found that the OEM rotor had a high spot on the outer edge for about 90° that was keeping the outboard pad from contacting 90% of the rotor. The inboard side was good. This will also push the pads out causing more stroke on each brake application
Update:
After my earlier escapade of losing a bearing buddy I had made two three hour round trips to a lake and back, 70mph on the interstate, 65mph on the state highways. Night before last I walked past my boat trailer and saw grease flung all over the drivers side front rim, yesterday I checked it out and found that bearing buddy had grease coming out around the interface between the bearing buddy and the hub, when I grabbed it, it was loose and was being held on by vacuum. I checked the rest, including the one I replaced which was fine, but on another I could see it was working itself loose and was in there catty wampus, the remaining one only took a light tap with my light dead blow to move it, so I replaced all three remaining ones that came with my boat. The interference fit of the new ones was dramatically tighter than the old ones which have been removed and replaced twice to check for water contamination, the one that had come loose this time had been R&R’d three times as I had to fix a grease seal there a while ago. I’m so glad I bought two sets when I replaced the first one that fell off.
I’ve come to the conclusion that bearing buddies are a single use item, maybe one removal and reinstall, maybe. Even though I was careful how I removed them the interference fit was greatly reduced after the initial install. So I’ll be buying a couple more sets to go on the shelf and I always carry a spare and a dead blow hammer now when I travel.
I replaced the plastic hub caps that came with my trailer with bearing buddy bras too. I had a heck of a time trying to pop the caps off to fill the bearings and had to pull the wheels off to get at the bearing grease zerk fittings. So I left the caps off and put on the bras instead. I would always have wet buddies as the caps were not a tight seal and let water in. But now with the bras my buddies are virtually dry.
