Grover70
- Ponte Vedra, FL
- FSH Deluxe
EDIT: Sorry - sometimes I just can not help myself...
If I understand what you are saying, anything that is below the upper deck should drain into the hull to the lower most point and follow the route to those two small drainage holes you can see if you remove the bait bucket holder and the clean out tray?On the first gen yamaha 240s there is free air between the inner hull (that the battery/batteries sit on and the outer hull. How much space is questionable. I suggest you drill a small pilot in the inner hull and use an uncooked noodle to measure the distance to the outer hull. To answer you question anything under the inner hull in this area should follow the v of the hull and drain into the bilge area.
Pretty much, with two caveats. One is floating foam - they do use it, per USCG, but where? - I don’t think we know. The other has to do with the bilge being the lowest point in the hull only when on plane or on a trailer - with the bow jacked up. Otherwise water will linger midship, somewhere inside the pseudo double hull.If I understand what you are saying, anything that is below the upper deck should drain into the hull to the lower most point and follow the route to those two small drainage holes you can see if you remove the bait bucket holder and the clean out tray?
...and seep in from the backside of your changing area floor drains if you haven't re-sealed those mounting flanges.Otherwise water will linger midship, somewhere inside the pseudo double hull...
Fortunately I figured that out when all else had failed. It feels strange now having a dry changing room......and seep in from the backside of your changing area floor drains if you haven't re-sealed those mounting flanges.
I hadn't thought about that. I think I just got nervous. Yeah, let me know what you see. It's never too late to drill again!Did you try looking up that way through the access panel in the swim platform? I think if it's supported it's go to be on pads and not solid? I could be wrong but that's the way the bulk of the liner I supported. So you could have simply just drilled into the wrong spot. I'll be working on my drains this weekend so I'll take a closer look
