The helm position - further back in the cockpit of any CC is a big factor, no doubt, and that is a very good point. Indeed, standing at the helm of my 240 I'm probably good 3-5ft forward of the helm position in a CC - which makes a HUGE difference in the amount of vertical movement as a hull pivots on its stern/transom.
The weight is a big factor, too, but not really relevant for this discussion as I believe these boats do not differ much at all (comparing the same hull lengths). Scarab will be literally within few hundred pounds of Yamaha, either way.
Some other considerations:
Jet boats tend to spend time in the air when "cruising" in rough water, lol. There is just not any good way around it: you are gonna catch some air. On a 2 hour long trip offshore in nice to moderate conditions you will be catching air and slamming the hull back in the water a thousand times.
In this regard, the new yammie hull with that "keel" tend cut through the water surface rather than slam/slap hard - and that makes a considerable difference in ride comfort (and safety). Add trim tabs, and you can have an okay ride in most conditions with up to 1-2ft waves (w/reasonably long period).
That said - the older/flatter 230 Yamaha hulls do very very well in the rough, but
those have been factory tested like NO OTHER jetboat ever. They also benefit hugely from trim tabs. Just ask
@Bruce.
But - here is the big one that no one mentioned yet:
I believe Yamaha is currently the only 24' jet boat with a
self bailing deck. And that is the key to surviving a swamping scare in ANY ocean-going open bow boat.
The last time I checked, the Chap and the Scarab decks drain into the bilge. That is far from ideal and I would not want to be too far offshore in one on a rough day. Sure, one can use a bow cover, which is a very good idea, but still. By comparison, you can get a foot of water in a yammie but as long as you can throttle the bow up all of that water goes quickly out - the scupper (and does not drain into the bilge which stays dry).
On balance, I would take the new 24 Yamaha off shore before anything else (in this category).
Between the "keeled" hull, self bailing deck, pump clean-out ports, higher free-board, reliable engines, and availability of a proven design for trim tabs that work - I would have to give it to the Yamaha.
A falling 2015+ AR240 Yamaha tower, possibly killing you, notwithstanding.
