Best or Most Used Lubricant / Protectant Spray
What Spray do you prefer for spraying your engine, parts, trailer, etc?
  • Total voters
    26
ToddW850
Destin, Florida
242X E-Series
Curious as to what is the most used Lubricant/Protectant Spray used by members. Which one are you guys the happiest with and does the best job? What do you guys use to spray and protect your engines, exposed metals, the trailer, etc...
I presently use cheap silicone spray from Walmart or O'reilly's, However, I think I am going to try RV slideout lubricant from Walmart in the Fall.
KY. note: Turning KXcam22 to KYcam22 gives it a whole new meaning. Cam.
Boshield T9 is safe to use on paints, plastics, vinyls, and rubbers. It leaves a waxy coating for protection. It was formulated by Boeing Aircraft Co. to protect its engines.
I've been using FluidFilm and like it.
