Bildge upgrade
jetboater4life
Rochester, MN 55901
X
I installed a 1000gpm float activated bildge in the bottom of my boat and used the correct diameter bilge hose, but I would like to replace the factory bilge which is 750gpm with the same 1000 gpm bilge (bought 2 of them) . I don't really want to run a new bildge line. Any issues with just hooking the larger bildge up to the smaller hose? With it being a secondary bilge, I don't see it getting used unless something catastrophic happens. Having it on a float means no more dead battery too.
Bilge pumps need to have their own discharge hoses, I’m sure the directions of the pump shows what size line is required.
Beyond the capacity requirements for each pump to flow properly when one pump turns on it will try and push water back onto the other pump. If something catastrophic happens then both pumps will be running and each will need their own discharge hose to perform at rated gph.
You can connect to a smaller diameter hose but it will limit your flow to be probably the same as the OEM pump and cause the larger pump to run harder and possibly overheat by trying to force more water into a smaller hose. Either leave alone or install the larger hose is my recommendation.
