AuburnVFR
- Auburn, AL
- SX
I am trying to figure out how to keep the rear storage compartments dry on a 2016 SX190. I keep it on a trailer, but the old shipping cover leaks when it rains and I find standing water in the rear compartments. I am waiting for a new cover, but at some point they will all start leaking. The cupholders are plugged and the transom and internal compartment plugs are open. I have several inches of water in the ski locker even with the plug open, but no signs of water in the bilge at the transom. The bilge pump in the engine compartment seems to drain the standing water from the ski locker, but it seems crazy to have to keep the battery/bilge pump on when trailered.
Am I correct in assuming that this water is leaking into the rear "dry" storage compartments?
Can I seal something to stop it from entering the storage area?
Is there a trick in getting the water into the bilge where it actually drains out?
Is there a non-cycling automatic bilge pump that fits where the OEM one is? Since the base sits below the floor of the engine compartment, I don't see where an external float or sensor would go unless water was already in the engine bay, and the internal float/sensor models appear to have a different footprint. I don't see where a direct wired second bilge pump in the transom bilge would help since it is already dry with the plugs open.
Thanks
Thanks
