Bilge and Pisser fittings
Rustynuts
Coos Bay, Oregon
242X E-Series
On our first week long trip with the new 242x I kept noticing the starboard side rear under seat storage carpet was wet, figured that is was from the wet grandkids sitting there but kept getting worse. Well I was swimming next to the boat and discovered there was just a hole where the bilge fitting should be. The outside flange had broke off and the hose had fallen inside so the bilge pump was just pumping water into the compartment, then draining back down into bilge repeat....Made a quick fix by removing the inner nut and screwing it on from the outside and wrapped with silicone tape to keep the nut from coming off.
I decided to replace the ugly pisser fittings while I was at it and found these nice half round ones at Blowison. The 3/4" pisser fitting requires the hole in the hull to be opened up just slightly which I did with a rat tail file and then used a Hillman 18mm black drain plug gasket on the fitting to cover up the small key slot in in the hull for the factory plastic fitting with a dab of white silicone. The 1" Bilge fitting fit a little loose in the factory hole so I used an o-ring on the fitting and it fit snug in the hole and added a dab of white silicone. I think these look MUCH better than the factory fittings.
https://www.blowsion.com/products/h...t/new-12-inch-45-degree-water-bypass-fittings
https://www.blowsion.com/products/hull-components/blowsion-billet/bilge-fitting-45-degree
It looks nice. Is it metal or plastic?
The fittings are Billet aluminum and are available in Black or Silver.
Quick thinking on your makeshift repair..... I'd spend a long while staring at it blankly before coming up with that one!
Ordered mine yesterday after whacking the pissers on the dock Sunday
How did you access the inner side of the hull to access the pissers to replace?
Your can reach up from the under seat compartment on the drivers side. Just open the seat up and look up inside towards the back and you will will see them.
I actually removed the seat on the driver side rear. It is a tight fit so a smaller person than me had to go in there and loosen and tighten stuff up
Probably depends on the boat. I'm 6'2" and 260lbs and had no problem just opening the seat and doing the work but I do have a 24' boat which probably has a larger rear seat than say a 21'. Either way its not a hard swap, it just is nice to have a helper on the outside when tightening.
looks super clean, You mentioned a gasket from Hillman? where did you find that?
Hillman is usually carried in large hardware/builders stores, I got mine at the local Ace Hardware and they are in the nut/bolt section. It was in a tray with assoreted oil drain plug gaskets.
awesome Thanks!
