bbar
- Other
- Other
- Other
Hi, Nautica rib jet 10. Yamaha 760 powered. There are no manuals for my boat so hoping that other makes use similar manufacturing techniques so that my questions can be answered. Need help with the following please:
I have a regular type bilge pump with a discharge hose in the engine compartment. Can't see where the discharge hose goes and don't see any thru hull fittings; so how do they get that water out of the boat?
There is a fitting in the cockpit for a flush hookup. The hose disappears under the seat . Where / how does it hook into the cooling system of the engine.
In the back of the hull, a hose comes in from the fitting at the left top of the jet pump outside . It goes up, makes a 90, comes down and goes into a hole at the top of the jet tunnel forward of the pump. Then I lose it. Any idea what that does and where it should go?
Thanks.
Thanks.
