Hellacool
So because I will be storing my boat at the marina and it could spend a day or two on the water before being put away I will install a second bilge, straight lined to the battery. Two questions / ideas:
Mounting - I am thinking of gluing a small piece of marine lumber or plastic to the hull then screw the bilge to that. I see many just glue the bilge straight to the floor. Anything wrong with that thought?
Outflow. From reading it is best to route a separate line because the stock hose can not flow enough for two. Would it be better to simply enlarge the stock hose (1.5 inch so I still only have one hole in my boat, just have to enlarge and not cut) and T into it from both bilges or is the two lines just the better option?
I plan to install a self sensing bilge, straight wired to the battery with in line fuse.
