Bilge indicator light
Mkwg1111
242 Limited S E-Series
Why is the Bilge indicator light flashing red on dash
I would think that indicates the bilge pump is operating either due to water or a stuck float/sensor. If there is no water you may want to remove the pump from its holder to see if there is any debris causing it to operate. Depending on it's age you may need to replace it.
When it turns red that means it is running.
Flashing red is usually an error indication in Connext, right?
Any idea what an Amber indicator light means?
