Rkick
- Scarab
- Other
- Other
Hello, wanted to seek some advice on the bilge pump issue I’m having on my 165.
The pump recognizes that’s there’s water that it needs to pump out but it does not turn on and it does not pump it out. I clearly see the red light on the switch go on and when I manually flip it it also does not come on. I have checked every single fuse on the boat and they all are ok. I have disconnected the cables to the battery and re connected everything a few times. I also just got a new battery and I know it’s charged since I also check that.
I cleaned out all the water and even remove the part that the water would go in to see if it might be clogged - which it was not.
At this point I have no other clue what to do. Does any one have any expirence with these bilge pumps?
Thanks
Thanks
