Krats
- Cary NC
- Limited S
Sorry if this has been discussed but, I'm in need of replacing my Rule 25d2m 500gpm bilge pump. My question revolves around "automatic". This bilge comes on every 2.5 minutes for one second to determine the presence of water. That is the spec thats integrated into the pump. There are other pumps that are defined as "automatic" but that is because they have an integrated float switch. My question is, if my current bilge pump is built with this automatic cycling integrated in the pump what does switching between "automatic" and "on" do at the Connext screen? My tought was to replace my current pump, with an automatic pump with an integrated float switch and simply wired to the existing wiring but turn the switch on at the helm to "on". Wouldn't that allow for the pump to cycle on with the float switch?
Thanks in advance.
Thanks in advance.
