nofd843
- Kathleen, GA
- FSH
I have a 2020 210 FSH Deluxe, I am trying to decipher the Bilge Pump. I keep hearing the bilge pumps are not auto, but only work if you turn them on, however I am confused. The wiring for the bilge pump is three wire, Brown (Auto), BrownWhite (manual) and Black (ground). The brown wire is ran to a fuse and then to the battery, the brownwhite wire is ran to the switch on the dash. The black is obviously to the ground. With all of this said shouldn't the pump operate when there is water in the bilge? What am I missing? Thanks
