wango tango
- michigan
- Scarab
- HO Impulse
If anyone found some small holes in their Bimini cover for no reason , I found out why?
I have a 2017 195 impulse with tower and Bimini cover that when not being used wraps around tower and then gets a outer cover zippered over it. I found at the end of season that it had small holes in it and looking further into it I found that the quick disconnects on the tower were rubbing holes in the top. I don't use it much so it's usually wrapped up and covered, which sits there rubbing holes in it.
This is a design flaw and should be corrected by scarab. Tower should have added protection for quick disconnects. Mine is still under warranty so I will check into this!
