Evildwarf
- Woodstock GA
- Limited
Is the bimini top frame on the 242 limited (no tower) designed to be in the upright stowed position for high speeds? I know the bimini should not be extended for any high speed running but can you leave it in the upright position? We usually put it all the way down before doing any higher speedy stuff.
Thought maybe someone had an experience or reason why it's better down or ok to leave up.
