Bimini support pole length
35tsc
Can someone tell me the center to center rear support pole length for a bimini top on a 2015 242 LS? When I got the boat this spring it came with the frame minus the rear support poles. I found some adjustable ones online but need to know what the general dimensions should be.
Thanks in advance.
I appreciate that - yes - number 7 in the above diagram is what i am looking for. I was trying to save $100 by buying the same poles without the yamaha part number.
You might be able to call them for dimensions. Maybe ask in a way that you want to double check before purchasing, or something like that.
Thanks in advance.
If your talking about the hollow tubing, West Marine carries it in 6 ft pieces for about $40. And you can cut down to size
Found this site from another thread. The Q/A at the end states they can replace poles. Maybe worth contacting them. They may know the correct size.
