DaBanker
- 212S
Hello everyone!
My wife and I purchased a 2012 Yamaha 212SS late last year. The few times we had the boat out I was paranoid that we would run the battery down and end up stranded. I decided then that I'd really like to add a second battery for peace of mind. After a ton of research I think I've settled on the Blue Sea - Add a Battery kit. It sounds like we can go with the 65 amp version even with twin engines but to be safe ill probably just go with the 120 amp version.
I have a few specific questions that I wasnt able to find answers to by searching the forum. I'm hoping someone or someones could help us out. As a side note my boat is currently in winter storage as it is 7 degrees in Ohio today! So I'm trying to be as prepared as possible for the start of the season.
1. I'd like to add a positive bus bar for the house battery (dont think I need one for the engine battery) and a negative bus bar. Do I need to run seperate cables from each battery to the negative bus bar? Or can i "pigtail?" The two negative terminals together and run one negative cable to the negative bus bar? Is there an amperage issue in doing this?
2. Does anyone know if the mounting pattern is the same between the stock battery switch (BEP?) and the Blue Sea - Add a Battery switch? Im hoping to put as few holes as possible in the boat.
3. It appears that most people aren't concerned with the starter isolation wire which I completely understand. However, if I decide to connect this wire where is the best place to splice in? Do I need to run from the ACR to under the dash? Or is there an easier area in the engine compartment?
4. Does the Blue Sea - Add a Battery ACR detect a charge from both sides (house and engine) or just one side (engine)? I'm still trying to determine if I will connect the ACR to the line or load side. If I wire the ACR to the line side I'd like to wire my battery charger to the house battery to cut down on the ACR cycling. My current plan is to leave the wires long enough that I can change the side in the future if needed. I dont yet own a nice dual bank charger so connecting to the load side wont do me much good from the start.
If anyone would like to post pictures of their installs I'd love to see as many as possible! Im still trying to figure out exactly the best place to mount the batteries in the compartment. And where to mount the bus bars.
Thanks for any assistance!
