BlueSea Mini Add-A-Battery Plus Kit - 65A 7655
dv_damian57
Cape Coral, FL
Anyone here using this kit? Looks to make things very simple. Not sure if we can use it on our boats (2019 SX190)?
I don't have it, I have a separate charger.... but the kit would work. the kit certainly would simplify installation and requires less wiring compared to having a separate charger.
So, this is the info I got back from BlueSea.
Thank you for the question. Most of the Yamaha jet boats I have dealt with have smaller Stator systems of less than 65 amps for charging. So that makes the 7655 a perfect fit for your system. Double check to be sure you are less than 65 amps to be sure. Here are a few links and job aids to help with the project. Take a look and ask any questions you may have.
So assuming that our boats have a 40amp this should work correct? Our boats use a 40amp?
It will be fine...stator max output is about 30-40 Amps, but some of that goes to running the boat, so maybe only 20-30A can ever make it to the battery.
I've not seen this one but I do have the Original Add A Battery Kit installed. Works like a charm.
Can you show a pic of how you installed your blue seas add a battery? Give a shout out to my sister, her hubby and my father! All live in Kailua.
Aloha! It would be easier to watch the install on the YT channel than do it in pics. Try this link. It goes to the 2nd of 4 videos that I did for my install.
Go Kailua!
-scott
