PaulyB
Jetboaters Commander
- Bumpass, VA
I helped @Norboo install a new bluetooth radio in his 2012 242 LS yesterday and after installing it we connected a phone to it via bluetooth. Everything worked great until he turned off the battery switch. After the battery switched was turned off and turned back on the memory from the bluetooth and the clock had both been erased? Is there a way to fix this without running a new wire from the battery to the Yellow wire on the radio? Also how much of a drain will that cause on a battery while it sits? Thanks
