madtom
- FSH Sport
Hi all.
First post. I am currently trying to setup our approved socially distanced family activities for the summer. I just located and bought a used 2019 FSH 210 with only 100 hrs.... since 2021s are completely sold out and 2022s...are hurry up and get your name on the list so you can wait in line. I did enough waiting in line when I was in the Army. It has been crazy how fast the used ones were disappearing. We already have jetski's and I live on the water. It is less than 3 ft of water for 200ft from our dock so a Yamaha was an natural choice.
Seller of the new to me boat was on the wait list for the new 25 ft FSH....I was glad to help him get ready for his new boat.
I am trying to setup my bunks for the FSH 210. Lift beams are already fixed to each other with connecting beams. it is an 8k piling lift so capacity isnt the issue.
I already have brackets for the I beams and am getting (4) 2x12x 12 ft planks to screw and glue together and make two bunks for my boat. I plan on initially putting carpet on it and next season something a little more slick.
I am looking for the angle to cut on top of the planks screwed together? 18 degrees, 19 degrees ???? trying to make the bunks match the hull. Has anyone made bunks for their 210 (AR,SX,FSH yamaha) hull yet?
I plan on making the back side of the bunks with a 2 inch or more notch in the back so the hull will naturally slope to the rear on the lift.....or add a block under the front beam to do the same thing.
if there are no others that have done this before i will post my solution.
Any suggestions on a canopy? should I do it? and get one? does it cut down on the use of the boat covers? if I do how much longer/ taller than the boat should it be.... since it will be on 4 pilings it will already be wider than boat.
Thanks again and glad to be here.
