Once you get the engine squared away figure out what let all the water in. Scupper maybe?
If not done already.... run the piss out of the motors (back and forth on the lake for an hour) to burn off any trapped moisture and follow the run with an oil change. Fogging the motor is good advice to protect from any corrosion between now and your next run.
Could it be that rocks are added to the sealant to prevent someone from digging in and making a simple repair; forcing them to buy an expensive replacement?What is that "crushed rock like" finish? Is that as designed?
