96Pirate
- Wake Forest, NC 27587
So these questions are directed to those that have the folding biminis that lay on the top of the rear seats.
So for the 1st couple of weeks of owning the boat I would trailer the boat with the bimini down in its folded position laying over the engine compartment. After a couple of weeks I noticed some imprints on the vinyl where the polls rest. I am sure this is from a combination of the bimini shifting while trailering but also from storing with the factory cover real tight. I wanted to add some protection there so I folded a couple of old t-shirts to lay under where the polls meet the vinyl. I keep them there for both trailering and storing with cover. This corrected the issue of the bimini rubbing the vinyl during trailering but because of the extra thickness it left a larger compression imprint in the foam when the cover is on tight. I started using the anti pooling polls but then read on here that some guys don't use them and just the tightness of the cover prevents any water pooling. So I have tried that and have stuck to it and it seems to be working fine but this could be causing the compression issue. So what to do?
So I thought I would try removing the bimini entirely for my long term storage and see how that works. This would prevent any compression/rubbing issues on the vinyl and would create a steeper angle for the water to run off. The potential problem now is the cover is actually resting on the top vinyl on the rear transom seatbacks and the cover does not seem to be as taught. Though I am thinking I would add the anti pooling polls for the winter so that would take care of both of these I think..
So some questions...
How do you trailer/store your boat and do you have issues with the vinyl where the bimini rests? How did you remedy it?
Has anyone tried to store their boat without the bimini stowed in its normal position? Pros/Cons?
Will the cover resting on the seatbacks cause any issues to the vinyl?
Thanks!
Seatback with imprints...
Bimini removed (would store in garage over the winter)
With cover on and bimini removed
Thanks!
