Boating Weather for the intercoastal FL
Florida
195S
If you are boating on the intercoastal what is the breakpoint for weather conditions based on the ocean forecast? (in southeast FL)
From my experience with sustained winds of over ~12mph, you will start having to deal with spray as you cut through chop/wakes, and probably not going to be an enjoyable outing.
I would factor in the way the wind is blowing as well. If North or South, the waves will build. If East or West, waves will still build in wider sections of the ICW (my statement assumes the ICW is running N to S).
What part of FL are you boating in?
I have boated the ICW between Hillsboro Inlet and Miami on 20+ MPH wind days and had no issues with my 210. I gave up on the ICW however. To many slow areas, to much boat traffic.
Thanks for your response!
SE Florida ICW. My boat is a 195S.
i use windy - 2ft sea is with somewhat calm wind is the only time i go off shore. Sea change so sometimes from 2 it goes 5ft mid day, still doable for my 190FSH.
Honestly just test your limits. There are parts of our ICW that aren’t even phased by 20+ mph winds.
Wind direction is a big factor as well. West winds down in Miami are favorable.
