Bow backrest retrofit for AR190
Estrkrz
Hi. I think to retrofit bow backrest from 2019-2021 AR195/SX195/195S - part number: F4V-U35B3- 00-00; 10-00; 20-00; 30-00 (color identification)
I am trying to find best color match to my boat upholstery, but unfortunately Yamaha USA itself is not helpful in this matter.
I wonder if you can share with me pictures of your backrest, so I see all color details with info on year, model and hull color? This is only way to talk to Yamaha USA and order right part.
Thanks in advance!
If you want a cheaper easier solution to just jazz up the front a little, have Jetboatpilot cut you some Seadek. It also helps protect the front from anchor scratches. I diamond pattern would probably look even better.
