bow rails loose
Ronald
branson mo
2014 limited ls
Both rails are lose. Is there a video out there on tightening them up..ive seen some posts about removing speakers etc..tx
To tighten the front mount of the handle you'll need to pull the speaker, 4 screws and your done. The nut that needs tightening is 1/2 inch and you'll need kind of a deep socket. For the back of the rail you need to climb under the seat and get to it from underneath (or pay a small kid to do it). Wear a shirt with long sleeves to keep from getting splinters from the fiberglass back there, that sucks.
If you can find some blue locktite to put on the threads before you tighten it up, it may help keep them from coming loose again.
bingo!
