Bulkhead Fuel Line Pass Through Protector Recall
erexa71
SD
FSH
Hello,
Did anyone else receive this recall notice? I scoured the forums and didn't see anything posted about this. My nearest dealer is a couple hours away and the way this notice reads, the bulkhead protector in question may very well be installed. Anyone have experience with this recall and/or be able to post a photo of what this protector would look like if it were installed? I have a 2022 252 FSH. Thank you, Eric
pull your fuel tank hatch and look where your fuel lines are connected to the tanks. Then trace them aft through where they pass through to the engine compartment firewall bulkhead and see if there is a grommet installed in the hole. I assume this is what they are referring to as a ( fuel line bulkhead protector). Disclaimer ( I do not have a FSH 25) however, most of the fuel systems in these boats are similar in how the fuel routes from the tank back to the engines.
Thanks for the feedback and photo. That was kind of my assumption as well.
Thanks for posting the question and the response. I also received this notice and was hoping someone else had already posted the question. Dixemon, what did you find on your boat?
As far as i know I was not a part of the Recall, I have all the necessary gear in place.
