Buying Used Boat Question
fsurock38
I’m going to possibly buy a 2014 ar192 tomorrow. Going to inspect it and take it out on the water first.
One question I already have is I noticed in the pictures, the engine doesn’t have the black cover that says high output. It’s like the cover was removed. Red flag or no? I don’t know if the engine has had any mods installed on it.
Ask where it is.
I thought at first this model didn’t come with that cover, but I see the other support bracketry for the cover. Maybe the owner just took it off to wash the engine?
Ask where it is.
The seller didn’t know. It’s at a boat dealer.
Okay,
Well there are a plethora of more important questions you should have for a used boat.
Compression test
how many hours are on the motor
get a yamaha tech to get into the ecu and check for how many hours, overheat alarms, or other trouble codes
what condition is the impeller and wear ring in.
Does the connext screen work properly
can you get the clean out plug in and out normally
does the bilge pump work, not just spin, install the plug and fill the engine bay with a hose and make sure the bilge pump works automatically and manually.
Make sure all of the lights work
What does the engine oil look and smell like
I think there is a tab in the FAQ about purchasing a used boat, as well as numerous threads on this subject which you can find using the search function. You would be well advised to study as much as you can from the resources on this site before purchasing this boat. Not that it is a bad boat, but rather it will tell you what to look for. Your wanting and sea trial is excellent! After the engine is fully warmed up go full throttle for at least 15 minutes to make sure it is not going to overheat on you.
Make sure everything works
Okay,
Compression test
Compression test was good. Oil, spark plug and new impeller have all been changed. No overheating when ran full throttle for extended time. Forgot to check oil… will double check that.
11 year old boat… I wouldn’t say the cover missing is a red flag. Things happen during service. Could have been cracked during an oil change and they just tossed it. If everything else is looking good, this has zero impact on buying decision.
Was this a salt or fresh water boat?
Also, if it is not too late... smell the oil. If the engine has overheated, they can change the oil, but it will still smell burned. Works for cars, too...
