jetboater4life
- Rochester, MN 55901
- X
After following another thread discussing the installation of a blue seas dual usb port (which I can't find now ) I decided to calculate what I thought the wire thickness should be. I then sent this in an email to Blue Seas and posted my question and their response below. So the point of this thread is: Do you think I'm doing this correctly or not? If not then what are your calculations on it.
My note to Blue Seas:
Hi,
I'd like your recommendation on the proper AWG for wiring this unit.
http://www.bluesea.com/products/1016/Dual_USB_Charger_Socket/featured
My calculations say an 18AWG wire can be used for a 20foot round trip distance. Here is how I think the calculation is supposed to go. Please correct me if you disagree. You need to calculate how much current the wire needs to carry. I would do this like this. There are two USB outputs on one of those plugs and I'll assume each one is capable of outputting 2.1A at 5V (the USB spec'd voltage). Converting that to watts would be V*I=W, so 5V*4.2A=21W Converting back to 12V DC coming from the battery gives us 21W/12V=1.75A. Assuming a 20 foot distance using Oms law I*R=V and targeting a 2% voltage drop at the usb plug you would solve for your max tolerable wire resistance like this 12V*0.98=11.76V -> 11.76V/1.75A= 6.72 Ohms of max resistance for the wire. From this table
http://www.cirris.com/testing/resistance/wire.html
an 18AWG wire has only 0.006385 Ohms per foot. So if your run of wire is 20 feet round trip then that is 0.0006385 Ohms/foot * 20 feet = 0.1277 Ohms. This is well below the 6.8 Ohms you need to maintain the proper voltage at the the plug. You also need to check the max current for the wire and 18AWG supports a a max current of 2.3Amps. I would use 16gauge
Here are a couple of calculators
http://www.gadgetjq.com/wiring_size_guide.htm
http://www.bulkwire.com/wireresistance.asp
http://www.offroaders.com/tech/12-volt-wire-gauge-amps.htm
Their response:
Good afternoon,
Thanks you for your question. Blue Sea systems also offers a wire sizing calculator called “Circuit Wizard” on our website. http://circuitwizard.bluesea.com/
Based on the information you’ve provided, our calculator agrees with you based on Ampacity. Since the lineal distance is 20’, the return wire will be the same length, so that’s 40’ total. With n allowable 10% voltage drop, Circuit Wizard recommends 16AWG.
It may be worth noting that ABYC recommends 16 AWG wire as the minimum size for use aboard boats. There are exceptions of course, for limited power circuits, but maybe this is a good choice for such a long wire run anyway.
I hope this feedback is helpful. Please let us know if you have any additional questions.
Engineering Manager
Hi,
Their response:
Good afternoon,
Engineering Manager
