Evildwarf
- Woodstock GA
- Limited
Typically you will see these vents on boats with stepped hulls. The boat might have 3 steps; one for slow speeds(entire hull), one for mid range(mid hull) and one for top end(aft portion of hull). The second and sometimes third steps have these vents to allow air to be sucked in and under the boat to aide in faster speed. Without the vent there is a brief period that the boat sticks to the water as it tries to rise. This vent can also allow air to mix under the hull and reduce drag.
This video does a good job explaining...
