Marie grade everything. Also, it all depends on what your trying to do with your system. I did a switched separate circuit for my boat because I like to go out in the ocean, and also because I like to play my radio that has 3 amps installed. So I wanted to isolate one battery, and be able to use another for back up. Kinda piece of mind. Or you can have one side a cranking battery, and the other side an AGM battery. You can switch to AGM for play time, and Cranking for the engine. AGM batteries are deep cycle, and have less CCA but will spread the charge out, and will also charge quickly. Cranking batteries will have a high initial spike to start the engines, but the charge will not last as long as a deep cycle.
http://www.boatingmag.com/how-to/how-to-install-marine-dual-battery-system
You can also connect them in parallel with no switch. This will spread the draw between both batteries, and it will give you a better CCA. But unless you have a high wattage alternator, charging times will be longer. Also, if you do this, you have to monitor your batteries condition often. Since there isnt a switch to separate the batteries in the circuit, if one battery is bad or will not hold a charge, it will affect your other battery. Then its a guessing game.
Only wire the batteries in series if you have a 24 volt system in your boat. You will fry almost everything if not a 24V system.
