Yes, did it break or are you looking to do the upgrade ?
@Zizzou 192 Pulling the engine is the first step in the service manuals for even some seemingly simple tasks.
Sorry I can’t answer that yet but by the next Sunday I should. If it’s a mr1 motor while you have it down make note of flywheel if it’s dimpled or slotted. If you have to order one you will need to know and so far I can’t find any on the outside of the motor to tell.upgrade ..no break yet
How does the starter start the engine?There is no flywheel.
As you noted, even a new 4 link chain can break after replacement. You can convert to the 5 link chain without changing the crank but it does require new cam gears and guides.
the shop I worked with quoted me $1,900 to replace the timing chain on the other engine with a new chain not an upgraded one. Attached is a pic of the quote. As expected, the parts were cheap the labor was not. Rates vary but the time on task should not. They estimated 10 hours and I believe them/been my go to guys for over a decade.
when I showed up at the shop to take pics they tech was doing the chain replacement. They did it with the engine installed and I am pretty sure that at least some of that time the tech was laying on his stomach while reaching into the engine compartment.
I couldn’t understand how any mechanic would attempt changing a timing chair while the engine was still in the boat until I saw your pics @Ronnie. The timing chains on my 07 non ho motors are on the rear of the engine, not the front like yours. At least that’s how I’m seeing them in your pics. Either way, pulling an engine would make that job so much easier. Imho, with the right tools to pull the engine, it couldn’t cost much more time if any at all.Here are a few pics of the engine while the timing chain was being replaced. The tech working on my boat is the owners’ son and he really had his S together. All the tools were lined up in order of use and the new and removed parts were arranged in the way they came out/needed to go back in. By the way he spoke/gave me the high level summary of what needed to be done it was clear he had done this many times before.
Should people replace their timing chains as preventive maintenance? I don’t know. What i do know is that to do so costs $1,900 here at a reputable shop in NCal. I trust my shade tree mechanic (he helped me replace the engines in my boat) but even he told me to go to a shop with experience do the timing chain replacement. This price climbs to about $2,500 if you have to replace a broken timing chain and the bent valves caused by it. Add $2,500 more if you want to upgrade the timing chain. Remember these are per engine prices. Honestly, I gambled hoping my chain would never break, I lost that bet and it ended my season immediately. I also had to wait a month just to bring my boat into the shop.
View attachment 198461View attachment 198462
