Can I have Bimini open while towing with the tower?
Coclouse
Charlotte, MI
So I have only had my '07 ar230 out once since I've bought it, but a question crossed my mind as I'm looking into wakeboards and kneeboards. Can I use my tower with the factory Bimini open? It looks like the rope may rub the back, but I'm not sure. Also what is the consensus about pulling tubes with the tower?
I do it all time, no problems
There should be no problem with the bimini out and using the tower. I do it all the time. The tubes may be another thing. I used to pull tubes on the tower, but started noticing a couple minor cracks in the boat near the mounts of the tower. Since then, I only use the hook on the back. YMMV.
