Mxracerzero
Well I am finally getting around to installing the thrust vectors and lateral thruster from the group buy. I am pretty mechanically inclined so this should be a cake walk. When I go to instal the lateral thruster there is not enough room for it so sit flush against the jet pump/nozzle because it is also hitting the ride plate.
After watching the install video from jet boat pilot I noticed a distinct difference. The space between the pump and ride plate appears to be much smaller on my 2017 ar195 then that in the video. Using a cheap level as a straight edge it does not appear that my ride plate is bent. Perhaps my pump is at a more aggressive angle for some unknown reason? The pump is tight and all parts are flush to there respective mating surfaces.
For reference there is only about 5mm clearance between the pump and ride plate. Thoughts?
