Sflaherty
- 212X
looking for suggestions on what to do next. I have a 2019 212x. I had to give it some gas to get off the lift yesterday and probably sucked up some sand doing so. The engine wouldn't go out of reverse to start with. I checked the clean out valves and there is nothing stuck in the blades. I removed the covers/buckets from each engine output and some sand fell out but not a lot. After i disconnected the covers I could move the engine to neutral. After putting them back on I can't move it out of neutral. Do i need to take the impeller out completely and check for sand?
