ratchetdu
- Las vegas 89148
- SR
So, Ive had an issue here and there with cavitiation before and usually able to get it to clear up or disappear... This time, its not going away... After 3 outings. Although does seem to be getting better/less...
Difference is... this is the first year Ive slipped versus trailering.
Ive done the usual reverse trick. Ive stuck my arm up in the clean out port as far as i can. Swam under boat and looked at intakes. Rubbed hands along grates. Felt edges of blades (they are dinged, but have been since day one 7 years ago).
Nothing there. All seems normal. I really dont want to have to put on trailer and pull the pump, but i think i'm out of options...
When i first noticed it, i went to plugs and pulled a tumbleweed from the clean out on port side. Same engine that is still cavitating? Odds are is something still there? Or should i look at pulling pump??
Also, only does it while getting on plane initially, when pulling boarder/tube, or right around 5-6K rpm then goes away. Also does it coming off plane and into slower speeds. Doesnt do it at all times... Is it OK to run if no cavitiation, just avoid those activites and rpm range for now until i pull later in season?
Sorry for long post. As always, thanks i advance for input...
