Glassman
- Redondo Beach, California, U.S.A.
Anyone use one?
I've been on the lookout for an affordable (cheap) device to boost the cell phone signal of my iPhone 5S - on AT&T.
They seem to range from a few cents for the little, paper thin passive type that goes on the back of the phone or in the case to several hundred dollars for a high powered device that can cook bacon too!
As you might expect, they range from "doesn't work, save your money" to "five stars-saved my life" in terms of performance.
I need for it to run on 12 volt - so one with an adaptor that will work in-home is ok.
Depending on where I am on the river I usually get signal, however it does vary. I'd like it to be somewhat portable so I could use it in the Toy hauler in the desert as well.
Any suggestions?
Any suggestions?
