Both my wear rings show wear on the bottom. Maybe 1/16". I can't find a way to adjust the impeller to be better centered in the hole. Is there an adjustment I'm not seeing?
I don't think there is any way to adjust it. If it's wearing down a spot it's because the wear ring is swelling in that area and the impeller is smoothing it out.
