Jameson Clark
- Laurens, SC
- X
While riding down the lake this past weekend, I suddenly had a low voltage alarm go off. Looked down and saw one battery at 10.6v and one at 14.4v. Stopped to take a look and see what was going on. Pulled the battery cover off and found the black wire from the charge sensing block had pulled out of the eyelet connector. When I did my mod to see separate voltages on the Connext screen, I noticed that black wire was pulled pretty tight and it was on my winter list to extend it. I ended up pulling the nut off one battery and wrapping the ground back onto it as a temporary fix and that took care of it. I'll take care of the permanent fix this week.
As a side note, this is the first time I have pulled the battery cover off and I also found a very large bolt down in there. As plenty others have said, I also found loose screws, nuts, bolts, washers all through the compartments and bilge of my boat when I got it but nothing anywhere close to this size. I am REALLY curious where in the heck this came from!!!
