dan144k
- Palatine, IL
When I got my boat 5 years ago it would randomly die while docking and tubing, figured out it was the the swim deck hatch safety switches, I adjusted them and problem went away for 4 years.
A few weeks ago the swim deck hatch started giving me problems again, when people would step in the middle while the boat was running.
I was gonna add some washers under rubber piece to reduce flexing, but could not find a longer screw to accommodate the added washers in my garage.
So I moved the rubber piece over, closer to edge of the panel. No more engine turning OFF when people walk on hatch and flex it. So simple. So cheap. Thrilled it solved the engine stopping problem.
Tested last night, solved problem.
