PJM22
- Scarab
- HO Impulse
I'm new to the forum and looking for some help. I have a 2015 scarab 215 that my family loves but we are getting sick of the mechanical issue with the engines. Last year was our first season and we put 90 hours on the boat before our first major problem. At that time the port engine wouldn't start and I took it to my dealer and was told that the supercharger failed and they needed to replace the engine and supercharger. The work was done under warrenty but it took 6 weeks and we suffered through many nice weekends in late summer without a boat. Two weeks ago the port engine would not start again. I limped back home and the motor started. At that time I cleared all the codes with my can doo and the boat ran fine for the rest of the day. Now the port engine has two codes that come back consistently p0267 and p0203. Both deal with a problem with the 3 fuel injector. The motor start and runs fine but it only runs on limited RPM's. There is a 1000 to 15oo rpm difference between the two motors once you get above 3000 rpm. I looked at all the grounds wires and made sure all wire harnesses are secure and I'm still getting the faults. What do you think - bad Fuel injector, wiring harness, maybe ECM? And is the limited rpms due to the faults or do you think that the supercharger may have gone bad again. The dealer that I purchase the boat from dropped the line and no longer can do warrantee work. Like to see if I can solve the problem so we don't lose any more weekends.
