Georgi Slavov
- FSH Sport
so last weekend I took a longer trip than usual. I run for about 45 mins straight at about 6300-6500 rpm. Once I arrived I shut the engine off. About 3-4 minutes later I had adjust my docking and Shortly after I started the boat I got a check engine and continuous beeping noise as well as engine temperature sign too.
I shut it off immediately checked the engine , oil and all was good. Started it back up and water was coming out from the side so pump was working and after I restarted it it did not give me the alert not the check engine was on. Water coming out of the side was hot at first. I raised the Rpms to 3 k to I creSe the flor and it cooled off. I run the boat after that and I this never happed again.
Anyone else had a similar experience? Did I do something wrong? Should I be concerned ?
Thanks
Any input will be greatly appreciated.
Thanks
