I just had the check engine come on with a flashing AL on the bottom left corner. The terminals are clean and the battery has been replaced as well. My boat is an Ar195 is there a way to rest this code?
Had this error yesterday on my way back to the dock. Pulled the clean out plug on the starboard engine and found a plastic bag wrapped around the shaft. Cleared the bag and the error went away.
I have the same issue on my 2016 242 Limited S E-series, started both engines, backed off lift ran for 2 min then check port engine light came on, tried very thing I could think of, had good water flow on both motors, shut off both motors and port will not start back up. I hit the diagnostic button and this is what showed anyone what this could be?
