FloJet
Jetboaters Commander
- Moore, Oklahoma
So this weekend after sitting out on a cover, when we were leaving the check port engine light came on. Everything seems to be running fine. I have power and rpm on both engines, seeing constant water flowing out the pee holes, but check port engine keeps beeping. After I loaded the boat up and started engine to push all of the water out, the check engine light did not come on then. Anyone know why this happened? Nothing seems to be sucked in intake grates.
Kinda scary as I had to cut 2 ropes from a friends Yamaha after day of surfing on his 242x. Never seen it where both engines sucked up the rope so has been thinking about safety and engine maintenance to keep things optimal.
