Check Engine light
mh9208
Hi, I'm new to the forum. I have a 2016 22' Rogue Jet Fastwater with a 6.2 Indmar Raptor 400. I only have 50 hours on the engine. The check engine light started coming on at about 20 hours. I've brought it back to the dealer, they said it was an O2 sensor. They changed it out and it did not solve the problem. The light started flashing again. The motor has always run great. All the fluids are good. Any help is appreciated. Thanks
On my Yamaha, Check Engine often indicates battery problem.
