check engine low voltage
thcobb1
Auburn, AL
So last week I got a check engine light on the port engine. everything seemed to run fine with the exception of the no wake assist would not work on the port side.
I took it in to a dealer to get the code and all that showed up was low voltage. However, I checked both the house and cranking battery. Both were showing fully charged.
What next?
BAD GROUND WIRE TO THE ENGINE is the usual culprit
