OnTheWater
Jetboaters Commander
- Denver, NC
- Boatless
- NA
- Other
- NA
Went to the slip to install a battery charger, because I was worried the bilge switch and pump would drain my batteries. After pulling cover and putting on a wakeboard rack, I went to start it prior to installing charger. Port side 1st - started, then long beep and I believe I saw a 'low voltage' warning flash below the tach. Starboard side was running fine. Turned both off, beep continued for about 30 seconds.
Charger is hooked up now and I'm getting a 'check engine' on port side. Is this related to my battery level possibly and I just need to wait for full charge?
