@chess boat won't start in the water
bronze_10
Raleigh / Wake Forest Area..
[USERGROUP=9]@HELP[/USERGROUP] @chess is on the water... his port engine won't start.. it will spin but not start.. we tried the lanyard, and pushing the bypass on the throttles to get more fuel but nothing is working.. it sounds like it is fuel starved.. any ideas?
Check hatch switches?
Fuses by battery? Hmmm sounds like electrical gremlin
Wait, starboard starts fine and runs?
Does port side try to chug chug chug when starting or just spin freely with starter?
Verified swim platform hatch switches engaged?
Bypass on throttles?
Yes to which one? If it chug chug chugs it may be trying to start and could be short on fuel or spark i assume fuel level is ok in i would warn against grounding plug to motor to check for spark because it can ignite fumes if the fuel is leaking!
Check for gasoline smell
Also, open up filter box and look for oil deposits and/or wet throttle bodies which can mean overfull oil or flooded engine with fuel
Spins freely... doesn't sound like it is getting fuel
I don't know how freely it is but could be lost compression from a spark plug blowout or something?
Gotta be the neutral switch, lanyard, no fuel, no spark
I would pull the speaker by the drivers foot and find the connectors for the lanyard switch, one for each motor. If you can't tell which one of for which motor disconnect both and then try the port motor.
I agree .. it sounds like the lanyard.. he removed and put it back a few times but for didn't help... I think he is gonna no wake it back home before he gets to far into it.. he is afraid his other one my stop for an unknown reason.. this is assuming he isn't far from home
That's good possibility!
Try jiggling around a little while trying to crank over
The lanyard switch is one plunger with two independent switches, one for each motor. I had one switch of my lanyard fail on my Yamaha and left it disconnected for about a year before replacing with an after market switch.
What year is his boat. . . . . . Did it run at all today? Timing chain issue?
Was he wake surfing and listed to that side?
It's an 05.. it ran fine on the way out.. they stopped for a bit and now nothing.. they took off the air filter and still couldn't smell any gas after messing with it for awhile
Leave the engine hatch open and try it. Sometimes after sitting, the humidity causes issues starting again. Just a thought.
