So i have never owned a boat before drove/rode in plenty but over the next couple years i plan on buying and jet boats caught my attention. I from the new england area so im a little concerned about stuff getting sucked up into the engine ive been reading thats a problem. My main questions are..
1. Which jet boat is also the best for ocean use
Are you concerned about saltwater or waves?
Really doesn’t change my answer.
Waves are pretty equal. Weight probably makes the biggest difference and these two are very close. I never was in them back to back at same location but over all I didn’t note a difference. If you are concerned about ride moving up a notch in length will be your biggest difference.
salt/reliability. when I owned mad seados I can tell you the standard comment was don’t let them run out of warranty. While I don’t think it appropriate to draw conclusions from that experience I mention it just to note that they went with a closed cooling system cause they couldn’t get them to last for shit with out it. They should not get bonus points for the closed system cause we think that should be better.
I have zero experience with closed system and can only relate what the mechanics say when I chat them up. With out fail it’s a nod that the closed system has improved reliability but yeah, get the Yamaha.
2. Which of the two yamaha or scarab is better in your opinion (i live close to a yamaha dealer that sells both)
Depends on what you value.
3. What features best separate the 2 models 210 vs 215
To get the best answers you really need to narrow down what boats you’re looking at and what kind of boating you hope to do.
Just hull wise looking at base models, clean out ports, second captain chair, and I’d add space.
the ports are definitely useful when needed. Not needing to jump in the water like I’m the ole islandia is nice.
I rarely get weeds that cause an issue and now I can pretty much predict it, but the handful of times it’s happened the ports are easy.
4. Whats the top speed between the engines in these two boats ive only seen reviews from ~2016 is it still current
Multiple engine options In both boats depending on model. If performance is your thing I’d say that’s scarabs goal.
Seems to me you can get 500 and maybe now 600 hp in the scarab. Think you need to get to the 24/25 Yamaha for that.
yeah man no issue.
I honesty think once you go look at them and know what kind of boating you really do the answer will be clear and you really didn’t need any of this.
Moar...
not to jinx myself but this every boat breaks thing, where not in the searay forum. And not to jinx myself or my buddy but each has 2018 21’ Yamaha and not a single broken yet. I get that broken may have different levels so let me put it this way,neither of us have had to limp home or had something that kept us from water.
maybe I have a soft definition of broken, but I’d say I come by it honesty having grow Up with searays.
we constantly limped in. Had to get a diesel repowered! More recently friend eventually had to bail on his errr. 2000 something 32 cause ithad Issue every time out. Bro in laws 24 he didn’t keep past warranty and hadissues that prevented him from getting on water. The 24s that comes out with me is of the same age and still kicking it. 2012-ish.
point of all that, I call bs in just expecting breakage these days. We’re way past say a car built pre-2000.
there seems to be plenty of really reliable boats. And they should be considering the maintenance schedule. ... it’s as bad as owning a BMW with an M badge in it.
