Rushfan67
Jetboaters Commander
- Raleigh, NC
- Other
- 222S
Hey everyone, I have a few questions that I need a little guidance on. I decided on adding a Clarion XC 2410 and wanted to get some wiring advice.
I’m going to mount it in the helm cabinet so as to keep the RCA’s shorter and have the run for the power and ground be the longer part. Am I correct in saying this? This is based on everything I have read.
Will 8 gauge work ok for this amp for the power and the ground? Also since that particular amp comes with a wiring harness for the ground and the power what is the best way to connect that to the long heavier gauge going back to the battery?
Last question.... if I add 2 more speakers could I leave the fronts running from the HU and run the rear and the 2 new ones in the mid area from the amp.
Thanks Everyone.
Thanks Everyone.
