- Corinth, TX (DFW)
last year I noticed a small crack on the underside edge of the clean out hatch, I noticed it because occasionally some discolored water would seap from it. I also noticed the starboard side of the hatch was a little spongey/hollow when you would step on it. I broke the whitecap t-latch handle off last year so I was removing it yesterday to put a new one on and the wood or what was left is flakey and rotted around the cutout. I am assuming most of that side has rotted out. I'm not exactly sure how it happened although the latch nut was only hand tight so maybe water made it through the seal on the top??
How should I fix it? I'm thinking of getting my dremel and cutting the whole underside out to thourghly scrape the rot out or take the entire support board out if I can and put a new one in or would it be better to only take half of it out? Is fiberglassing the new peice in going to be a big deal if I've never done it before? any ideas would be appreciated.
maybe @Glassman
maybe @Glassman
